Posted May 29, 200917 yr I recently have gotten an old school amp and when i hooked it up on monday everything sounded great. Yesterday i go out and start play i hear a buzzing/static sound coming from the driverside. so I turn up the volume and did a fade from left to right and the sound was only coming from the driver side. I went and cut the speaker wire and ground wire to give it a fresh end and it that seemed to stop it. An hour later went out the sound was back so i swaped the rcas around took channel ones rca and plug it into channel two and vice versa. Im going out now to see if that worked and ill let u know.... nope it is still ther but it seems to get softer as it plays but as soon as i restart the truck it happens again..What do u guys think could be the problem?? Edited May 29, 200917 yr by sqjeep
May 29, 200917 yr Author so when you faded it, it stopped buzzing?yes and no if i would fade it to the buzzing side the buzzing came more pronounced and when it faded it all the way to the opposite side the buzzing goes away.Im going to try a different amp i have laying around it see if it stops
