Posted May 29, 200917 yr I will be running them of the 3 & 4th channel of my sundown 50.4.I havent a clue right now how to hook them upThanks for any helpSpecifications: *Power handling: 70 watts RMS/110 watts max *VCdia: 1" *Le: 0.53 mH *Impedance: 4 ohms *Re: 2.9 ohms *Frequency response: 48-20,000 Hz *Fs: 48 Hz *SPL: 86 dB 1W/1m *Vas: 0.64 cu. ft. *Qms: 2.63 *Qes: 0.85 *Qts: 0.64 *Xmax: 2.5 mm *Tweeter crossover: 10 kHz @ 6 dB/octave *Dimensions: A: 6-1/2", B: 5-3/4", C: 3- Edited May 29, 200917 yr by Jacob86
May 29, 200917 yr What sub is that? i take that it's from PE?Edit: or is that a mid? Edited May 29, 200917 yr by DeepSubBoy
May 29, 200917 yr Author sorry its a coax, and its from pehere's a linkhttp://www.parts-express.com/pe/showdetl.c...tnumber=299-275
May 30, 200917 yr And if you have some processing on the channels high pass them up somewhere near 100hz if you wail on your system, lower if you don't and can hear midbass distortion.
May 30, 200917 yr Author So do I just need to y the positive and negative from the amp so I can hook up to the 2 +s and 2 -s? I was thinking that would give me a wired ohm load
May 30, 200917 yr What? You have 2 speakers, correct? And 2 amplifier channels, correct? Wire one speaker straight to each channel.
June 1, 200917 yr from what I see looking at the pictures of that coaxial, those are just 2 different size terminals for the same connection, so just pick whichever one is better for your wire size.
June 1, 200917 yr Author from what I see looking at the pictures of that coaxial, those are just 2 different size terminals for the same connection, so just pick whichever one is better for your wire size.Thank you
June 1, 200917 yr My bad, I should have looked more closely. From the link it appears those are actually separate terminals for each component of the coaxial. One set of terminals for the tweeter, one set for the mid. The side with the capacitor is for the tweeter. You'll want to hook both positives to the positive on one channel of the amp, and both negatives to the negative on that channel of the amp.If you only hook up one you'll either only get mid or only get tweeter sound.
June 1, 200917 yr Author My bad, I should have looked more closely. From the link it appears those are actually separate terminals for each component of the coaxial. One set of terminals for the tweeter, one set for the mid. The side with the capacitor is for the tweeter. You'll want to hook both positives to the positive on one channel of the amp, and both negatives to the negative on that channel of the amp.If you only hook up one you'll either only get mid or only get tweeter sound.thanks for hanging in there with me
