Posted May 30, 200917 yr I have a pair of Alpine Type-R's dual 4 ohm version. I currently have them parallel to a 2 ohm load at the amp. I fear as though my amp sucks (i know this for a fact its a Volfenhag). My question to the amp gurus is what amp i should use for the pair. I could always parallel the remaining wires to a 1 ohm load to a mono block. Wondering what kind of amp would be the best.Power Handling * Power Range: 200 - 500 Watts * RMS Power Handling: 500 Watts * Peak Power Handling: 1500 WattsDimensions * Mounting Depth: 195 mm (7.7'') * Mounting Diameter: 275 mm (10.9'') * Displacement: 0.071 cu. ft (Front Mount) * Added Volume: 0.085 cu. ft. (Reverse Mount, Magnet Out)General * Frequency Response: 25Hz - 500HzWhile I'm in the market I also have a pair of RE-SX12's waiting in the wings perhaps I could get some recommendations on an amp for those. Both are DVC 2 ohm.12"Electrical Q Value -Qes: 0.32Mechanical Q Value -Qms: 4.4Total Speaker Q Value -Qts: 0.30Free Air Resonance -Fs: 30.6 HzEquivalent Compliance -Vas: 47.6 litersOne-Way, Linear Excursion -Xmax: 22 mmEfficiency -SPL 1W/1m: 88.1 dB SPLEffective Piston Area -Sd: 480 cm^2DC Resistance -Re: 1.9 ohmNominal Impedance -Znom: Dual 2/4 ohmThermal Power Handling -Pe: 1000 WForce Factor -Bl: 21
May 30, 200917 yr Author thanks for the heads up shizzz i've really been looking at the sundowns i've seen alot of high power systems using them so i'm sure they are good
