Hey wussup Guys,
Can sumone tell me what would be the best way to power up and wire these subs together. I'm just about done making a fiberglass enclosure for them.its all one chamber. Should i use one amp two etc. The 3 subs are dvc 15" fosgate 2 ohm 250 rms P2d215 .After the box i will be making a panel on the door for one 8" sub and an 6-3/4 component set along with two component sets in the rear.
Help me understand the science of installation. i want to blueprint the install but dont really know where to start.
thanks
Edited by illswag1619
Well you can wire them out to either come out with 1.333 ohms or 3 ohms.
also 12 ohms but all these impedances arent not good for many amps. so i would wire two together on one amp and wire the other sub to another amp, or evn go buy another sub and have two subs one each amp
just get a 1ohm amp and run it at 1.33 i doubt you will see massive loss in output. and if its a pretty fiberglass box output is mostly likley not the most important anyway. most 1000d run at 1 ohm.. so 3 250w rms woofers at 1.33 should be just fine. OR get a 2ohm amp and hope it likes 1.33ohm OR 3 small 1ohm or 4ohm amps.
Edited by AlanHall
I vote 1.33ohms. Makes sense.
Awesome, i see the light! so how would i wire them down to get 1.3 ohms? series, parallel? speaker 1 2 3 ?
I'm not even sure. I havn't figured out what subs to buy for the doors. Any suggs? i want a kik ass mid, which is my reason behind the 8's in the doors. and sealing the doors up as much as possible with some second skin. Am i going down the right road?
with all the mat in the doors. some nice 6.5s would give decent mdbass.. but the bigger speakers would just look kool.
