Posted June 3, 200916 yr Clarion DXZ576USB4) SoundStream TRC.6n'sCrunch P1800.4'08 RE XXX 15" D2Memphis 4KW4ft^3 @ 33hz (as RE suggested, building a new one!!)4/0 power and groundsBig 3 in 2/0Ohio Generator 300A alt. with tiny pulleypair of BatCap 2000's in the trunk With the above setup (different subwoofer) what class would that put me in? Also if i decided to go with a wall, I assume that would change it so what class would a wall put me in? It is going to be a single 15" either way... amp running at 1ohm
June 4, 200916 yr If it's Db Drag then more than likely you'd be in Superstreet no wall. That is if your setup is below the window line in your vehicle. If you did a wall then you'd be in Superstreet 1-2 if you were going to use 1-2 woofers. Other organizations vary dramatically in classes by things as small as fuse ratings.
