Posted June 7, 200917 yr I was wondering if I needed to solder the ends of my power wire(1/0 knuconcepts) before i put it into my amps. Same goes for the speaker wire going to my sub and speakers. Also, can i just get a cheap battery powered soldering iron, or do i have to get a nicer one? thanks.
June 7, 200917 yr Do you mean as in tinning the leads? If so, no, just strip the wire, insert and tighten.
June 8, 200917 yr Do not get the battery powered iron. I bought one trying to be cheap and it's now in the trash.
