Posted June 11, 200917 yr So... i was wondering what are the effects of running 2 giant gobs of wire out of a wall(8 runs of 8awg per side), one on each side of the wall and filling it in with whatever.this would just seem to cause some loss in SPL wouldnt it?I dont know if i just fill it in with silicone or should i shoot expanding foam in there... i dont know?Also, when i'm messing with the wire any, if the wire gets moved through the hole, would it "un-seal" the hole?
June 11, 200917 yr Author you know, after sitting and thinkin about it, i think i know what i'll do.I'll cut the 2 holes out i need then run like a 3" long pvc pipe through it. glue it and seal it up real good.then get 2 grommets that would fit the 2 ends of the pvc pipe.run all the wire through the pipe then stick the nozzle in there and fill the entire pvc pipe up with foam. that should do it.
June 11, 200917 yr Author thought about it forever, but the cost of extra wire, extra terminals, bolts, and the fear of them coming loose... i venture to this method.
June 12, 200917 yr I just thought it'd be less work on your part....The resin should fill the gaps between the wiresand form up solid enough to never move.It works for me fine....LOL Edited June 12, 200917 yr by Jay-C76
June 12, 200917 yr Author i see, i dont have any resin left over from any job but i do have pvc pipe like crazy left over.
June 12, 200917 yr A little can is only a few bucks....I bet there's enough in the couch and pockets of dirty laundry...LOL
June 12, 200917 yr BOLTSSSSS man bolts.... Get some 1/4 brass bolts, washers, and nuts. Pick up some 1/4 8ga ring terminals and get to work. Personally man iv done it that way forever with no issues and it allows you to change up ohm loads in a snap.
June 12, 200917 yr Author r u sure brass is a good conductor?It's somewhere around #7 as the most conductive metal. Wouldn't i loose a good portion of power due to resistance in brass bolts?
June 13, 200917 yr I like to use bolts aswell. It does make it a lot easier to (dis)connect the terminal much easier.
June 13, 200917 yr Wasn't it you that made some buss bars? It wouldn't be so hard to seal one of them off if they were coming through the mdf.
June 14, 200917 yr Author ok u guys better come up with somethin different or i will continue to run all wire through pvc pipe and seal it with expanding foam...I just got back from measuring the resistance across brass bolts and i got between 0.15-0.18 ohms.This translates as follows-For every 1,000w being sent from the amp, only 850-870w is getting through.So, when i'm over here running 7,000w of power.Theoretically, if the amps were to be able to output 7,000w, the subs would only see up to a maximum of 6,087w.That's enough to lose a few tenths of a Db easily.
June 14, 200917 yr Don't forget to account for the resistance of the test leads when measuring. It's negligible but it's there.Did you check the resistance of the same length of wire ?
June 14, 200917 yr you can run your wire through the wall just use resin and matting to seal it the best way to run wires is wire to wire any way
June 14, 200917 yr Author ok, i got a tap n dye set so i'm thinkin bout just buyin this copper rodas mentioned before and threading the outside, like all-thread.i'm gonna stop by 3 different electrical shops this week and try to findsome pure copper nuts and washers(optional). i'm also gonna be lookinfor pure copper ring terminals but if not, i'll just get the gold plated kind.and for other poster-probes resistance- 0.25-0.28brass resistance- 0.40-0.46resistance in brass bolts- 0.15-0.18in my book- terrible.i'm hopin using copper all-thread and nuts should give lower resistance thanbrass bolts and steel nuts.
