Posted June 22, 200917 yr my friend has a 2001 s10 xcab and wonts to pound the groung he has a budget of $2500 and needs everthing--hu-amps-mids-hi--subs--box---what we have now is a used 225amp alt-$100.00 and 3-kinetik 800's-$275.00 new got a good deal--he's looking at a hifonics xxv colossus-$550.00--tell me what you think would be a good setup for the truck--he has $2125.00 left to spend let us no what you think
June 22, 200917 yr i dont like to set my equipment selection based on a precise money limit.It may go over or under... dont know til you get goin with the build.The best thing to do is the following-Measure how much room you could possibly use for the subs.I dont care if u get 10,000 cuft... Just because you may think u have too large a room to fill... think again...Base your sub stage plan according to the room available. Once we have that... everything else is mostly downhill.
June 22, 200917 yr Author i think we have like 8.5cf net to work with he has no perfered equipment and the $2500.00 is his limit he just got married so thats it
June 22, 200917 yr just a FYI... how would u know the NET volume if you do not know the port displacement or the sub displacement yet?What is the MAXIMUM external volume i can use. I will use that to design an enclosure.And i also need the ACTUAL dimensions so i know how the subs and port will sit.I design boxes in CAD software so precision specs are necessary.
June 23, 200917 yr Author this is the room i have for the box 45''w 24''tall 16''bottom 13''top---that all outside it like 9.0cf thanks for the help with the box
