Posted June 24, 200917 yr Finally got around to taking pics of my HellFire 1000.1 Pics & Test Results From Diablo Audio Technologies Forum.Bill From DAT ForumsHF-1000.1 Testing ResultsThis amplifier’s size is at 410.5mmX260mmX55mm(W,L,H).Specifications1000W rms Class-D amplifier.1 ohm load stable.Double Side PCB and SMD components.Adjustable Input level, LPF, Subsonic, bass boost function, Q control.Advanced short circuit, overload, over heat protection.Advanced clip limit / thermal power limit function.Easy bridgable with same amplifier.Optional remote controller.Testing Conditions 1. Power supply: 14.4V DC power supply2. Test signal: 50Hz sine wave.3. Loads: Resistor dummy load.4. Environment: 77 degrees F, open air.5. Relative humidity: 70%.6. Instrument: Audio Precision SYS-2322A.Power TestingRMS power/ (1ohm) RMS power/ (2ohm) RMS power/(4ohm)RMS power5% 1920W 1220W 550W3% 1700W 1060W 480W2% 1570W 920 W 395W1% 1450W 850 W 380WEfficiency Load 4 OHM 2 OHM 1 OHMEfficiency (THD+N @ 1 % ) 89.6% 83.7% 76.0%4ohm Testing2ohm Testing1ohm TestingSubsonic Filter Response Bass Boost ReponseBass boost Q control (bass boost frequency set at 50 Hz)Protect FunctionOverload:Protect when output current reach 75A. (Protect when load resistance less than 0.8ohm at fullscale power.)Short Circuit:Full rated power short circuit protect test: passed.Full rated power long last short circuit test: 10 minutes passed.Over temperature:Limit output power while inner temperature reach 167 degrees F, protect while innertemperature reach 185 degrees F.Low voltage:Protect while power supply voltage lower than 7.8V.Power limit / Clip limit.Clip limit while THD+N≥1%.Power limit while inner temperature over 167 degrees F.Bridge methodHF-1000.1 can be bridged with same amplifier through single RCA cable.All the adjustable functions on slave amplifier will follow master once be bridged.
