July 11, 200917 yr Author i am almost tempted to make mini enclosures for my second set of tweets and mount them on my dash ... ill fill in my door holes with a set of tweets running off the h/u
July 20, 200916 yr Author sorry this took so long to get posted ... havent really had time to upload pics ... still some problems ... waiting on my t8004 to get back to meleveled out floor deadenedwires organized and mounting plates alignedamps mountedfloor in placespacer mountedspacers deadenedspeakers mountedburnt fingers from soldering iron ;(box cuticon 12 =)installedstill have to put in the new kenwood dvx9140 that i am going to buy, i need to still do some custom fabrication on the box (it will be a suprise when it gets done), and still need to build a middle piece in between the rear seats to house my batteries that i still have to buy lol ... also waiting on my alternator >
July 23, 200916 yr Looks good Lucky.How do you like the Re comps? Those mids look like they are on steroids.I want both your amps.
July 23, 200916 yr Author Looks good Lucky.How do you like the Re comps? Those mids look like they are on steroids.I want both your amps. for the short amount of time i had them in they bumped ... i had to take them out because the t8004 was putting out dc instead of ac on one channel and ruined a mid ... they were vibrating the floor xd over at 80hz ... pretty much just an incredible speaker ... i ran them full range just because and they were fine with 180 watts each lol
July 23, 200916 yr Author btw id rather a different set of amps ... if i could return them i would .... they are power pigs with a 500 and 150 amp fuse rating ... wish the sundown 4500 watt amp was out
August 18, 200916 yr OK, lets revive this build log.I need you to post what you are gonna be running in your wall.I need to know the subs, the amps and the batteries that are going to be used.This is the information i got off of your video, if it does not match up to your Aviator, let me know immediately before i start the build process.Baffle = right behind front seat areaHeight - 42.25" for baffle height, 38" once over the hump.Width - 50" in baffle location, 44" wide throughout the rest of the vehicle. Width 2 - 41.75" wide if box goes to the headliner.. Depth - 37" on the hump, 63" total.2 questions i have-Depth - am i to assume that you can use 26" of depth in between the hump and front seats?If this is true, how close would the box be from touching the seats?and other question - when measuring from bottom up, how high can i go before the width starts shrinking from 44" to 41.75"?The measurements you did at the VERY back of the vehicle are irrelevant for the box design as you stated your equipment will be installed back there.I just need to be able to draw it out as square as possible without having to contour the design every few inches.The front WILL be bigger than the back, but i do need to know the above questions before i start.
