Posted June 28, 200916 yr How do I hook up the o-scope to tune my 1. Sub amp, and 2. component amp.I need to know the settings, and what to set the dials on, thanks.
June 28, 200916 yr you run the probes to the speaker terminals.Start cranking the gain until the signal clips on the oscope.
June 28, 200916 yr Don't forget to have the speakers connected when testing Use a 50hz tone for the sub amp and 1kHz tone for the component amp.
June 29, 200916 yr If you use your speakers as a load, unplug your tweets and listen while you do it. If you hear stress turn it down.
