I am looking for some 6.5 inch components, RIght now i have a set of Swiss Audio sak-650's in small sealed boxes and Pioneer Ts-A1702c which are also 6.5 inch but i built small boxes tuned to about 45 for those. I would like something better than this and i would put them in the ported box. I am using these at home so mounting stuff is not a problem. Also for me the pioneers are better. what would you recommend?
Also price is kinda of an issue, so the cheaper the better. Thanks
I Used To Run Rainbow Components Active, I Can't Remember The Exact Name, But They Were Around $280 A Set.
Very Good Components, Only Reason I Changed Them Out Is Because I Went To A Low-Tuned "Get Loud And Sound Damn Good" Setup In My Daily Driver, The Rainbows Were More Suited To SQ Applications. If You Are Able To Run Without Passive Crossovers Or Can Build Your Own, I'd Look Into Maybe Some Mach 5 Audio MLI-6.5"s And Some LPG 25NFA's Or Seas Prestige Series Tweeters If You're Strapped For Cash. I've Never Heard Either Set You Mentioned Above So I Could'nt Say If This Helps Or Not.
Edited by BigCProductions99
