Posted July 13, 200917 yr wat head unit i should get for and suv for Fi BTL 12 or 15" and high and mid speakers which one r good high and med speakers
July 14, 200917 yr It all depends on what you are looking in a head unit. what r u looking for in a head unit
July 14, 200917 yr Author It all depends on what you are looking in a head unit. what r u looking for in a head unitan in dash head unit wit aux cd dvd chinese junk has mid tres bass all of chinese junk
July 14, 200917 yr just check the pre volts on it you should go about a 6 volt or so. I wouldn't go to an 8 volt unless you are going to get a 8 volt compatible amp... If not you will smoke amp after amp.
July 14, 200917 yr Author just check the pre volts on it you should go about a 6 volt or so. I wouldn't go to an 8 volt unless you are going to get a 8 volt compatible amp... If not you will smoke amp after amp.well I AM A get an sundown saz-4500d amp so wat eva head unit could handle chinese junk i wanna get u kno so which name brand u really know thats good
July 14, 200917 yr well I AM A get an sundown saz-4500d amp so wat eva head unit could handle chinese junk i wanna get u kno so which name brand u really know thats goodwhat? i think before looking at a h/u you should be concerned about your charging system ... judging by what i could read from your post it seems that you do not really have a clear idea of what you need as far as anything goes ... you probably want that amp because it puts out 4500+ watts ... the problem with that amp is if you do not have a good charging system your amp will either shut off or shut you car off on every hit because of drastic voltage drops... you are going to need an upgraded alternator, upgrade all your wiring, not to mention you will most likely have to run 2 strands of 1/0 to that amp, and most likely will need to stick a couple of batteries in
July 14, 200917 yr well I AM A get an sundown saz-4500d amp so wat eva head unit could handle chinese junk i wanna get u kno so which name brand u really know thats goodwhat? i think before looking at a h/u you should be concerned about your charging system ... judging by what i could read from your post it seems that you do not really have a clear idea of what you need as far as anything goes ... you probably want that amp because it puts out 4500+ watts ... the problem with that amp is if you do not have a good charging system your amp will either shut off or shut you car off on every hit because of drastic voltage drops... you are going to need an upgraded alternator, upgrade all your wiring, not to mention you will most likely have to run 2 strands of 1/0 to that amp, and most likely will need to stick a couple of batteries inI will have to agree with u. That amp is going to be a power pig for a class D that's a lot of watts. I wish that I could get one two. Lol
July 15, 200917 yr will have to agree with u. That amp is going to be a power pig for a class D that's a lot of watts. I wish that I could get one two. Lolu know how much current draw? around 6?
July 15, 200917 yr will have to agree with u. That amp is going to be a power pig for a class D that's a lot of watts. I wish that I could get one two. Lolu know how much current draw? around 6?I'm not sure the spec's haven't been released yet. But from what I can tell the will take as much power as u can send them.... They did the testing on the 4500d on 12V and 17V I beleave. And I know that Jacob runs his at 16V for burps
July 15, 200917 yr just check the pre volts on it you should go about a 6 volt or so. I wouldn't go to an 8 volt unless you are going to get a 8 volt compatible amp... If not you will smoke amp after amp.LOL, you don't need 6 volts out from a headunit. There is a reason that you buy an amplifier.
July 15, 200917 yr just check the pre volts on it you should go about a 6 volt or so. I wouldn't go to an 8 volt unless you are going to get a 8 volt compatible amp... If not you will smoke amp after amp.LOL, you don't need 6 volts out from a headunit. There is a reason that you buy an amplifier.But the lower the pre volts the less sound ur amp puts out. And it dose not sound as good because the amp has to work harder... Is this not correct??
