Posted July 16, 200917 yr is it the same signal as the front rca output ... i do not listen to surround sound music or dvds so will the left rear sound exactly the same as the left front (same thing with the right side)? ... reason being i have 2 sets of components in the front and have my rears running off the high levels ... i wanted to run my front components using the front and rear rcas so i can adjust the kicks independently from the doors
