Posted July 19, 200916 yr I need help with a box design for a 15" Mach5Audio MAW sub. The recommended sealed box size for this sub is 62 litres (2.2 cu.ft.) 30hz tuning. I would like an enclosure designed exactly to these specs if possible.Thanks in advance!
July 19, 200916 yr Do you have any dimensions that are limited by the size of your cargo area?Otherwise 18"h x 18"w x 16.5" deep will work (outside dimensions, using 3/4" wood). Or 18"h x 26"w x 11.5" deep.
