Posted July 22, 200917 yr Here is my 3rd system in this truck. 1st was 2 12" Memphis PR's in SMALL PreFab Enclosure, & Cheap 400 Watt Amp2nd was a 10" SSA Icon in Ported Box built by Audibel Customs & MTX 600 Watt AmpNow 3rd: Audioque 12" (Purchased Online This Morning) , 2.20-2.50 Cu. Ft. Tune to ~37 HZ ~32 Sq. In. Of Port, HF 1000.1, Second Skin on rear cab wallThis will be the first box I build for a system so I'm hoping all goes good.Second Skin Arrived & InstalledAlso Purchased a Tox Kit from eBay to remove seatsHF 1000.1Pioneer-5000UB & Flash Drive & Amp Bass KnobWiring under driver seat that's going to get organized.EDIT: Also Box Design & I'll hopefully get some Rockford Components and a Amp to replace front speakers, and front tweeter.If you have any tips, or advice please let me know, Edited July 22, 200917 yr by tech2332
July 22, 200917 yr Author Also, I have a question for the box.Should I get a terminal cup or should I just drill a hole and squeeze the wires through and put the wires through the box?How do you guys seal the hole? Can I use fiberglass to seal it?
July 23, 200917 yr Honestly, a terminal cup would be fine, just run silicone around the cup from the inside. It's not a lot of power so runnin 8-12awg speaker wire through a cup isn't gonna effect anything even if competing.
July 23, 200917 yr Author Honestly, a terminal cup would be fine, just run silicone around the cup from the inside. It's not a lot of power so runnin 8-12awg speaker wire through a cup isn't gonna effect anything even if competing.I know, it's not really for competing or anything just the ease of doing it. Just to lazy to buy a terminal cup.
July 23, 200917 yr Lol, ok then get a scrap piece of wood and start pulling out drill bits. Find one that makes you have to force the wire through the drill hole.Once you find that, use that for the wire then silicone II around the hole after the wire is ran through on the inside AND outside."Second Skin Arrived & Installed Also Purchased a Tox Kit from eBay to remove seats"You know, lol, when i first read that, i thought u were chemically diluting gases in your truck to remove your seats.. I was sittin here thinkin.. Damn, they really don't want you modifyin this vehicle do they?
July 23, 200917 yr Author Alright, thanks for the tips. Oh crap, I just noticed I spelled Torx wrong. LolDang it I can't edit it. Edited July 23, 200917 yr by tech2332
July 30, 200917 yr Author Got Wood & Glue SuppliesAlso Got Another Package TodayCompared to SSA 10" IconHopefully start on box by the end of this week.
July 30, 200917 yr Author Updated Design: I now plan on using 1 6" Aero port firing out the drivers side. It will only have the external aero, the inside will be "aeroless".
July 30, 200917 yr Author nice sub and box design.you still trying to sell that icon?Thanks, and yea i'm still trying.
August 6, 200917 yr Author Picked up some Fiberglass @ HomeDepot.Start applying this tomorrow morning and if I need more I'll go pick some up.$30 W/ Tax( I only paid $10 since I found a $20 on the ground. )
August 26, 200916 yr good looking build so far. Your box is similar to mine, but I'm running 10's. How do you like the new truck?
