Not finding much online about this but wanted to know if u can run a Stetson 10K under 1 ohm (0.67) for daily?
I thought those amps weren't supposed to be run daily anyways
I had a 2k6d it didn't like being ran at 1 ohm (rated @ 2 ohms) when it got hot it it would go into protect if i tried to get loud with it. very power hungry also. i would stick with the sundowns. that's what i switched too and no problems. I would only use it if i got it for cheap. if you blow it i doubt you would get allot of cs.
  • 2 weeks later...
DO NOT DO IT, PERIOD.
The Brazil amps are all very high voltage designs... no reason to run them under 1 ohm anyway. Try to re-wire higher... such as 1.33
