i was told there was a video online of an explorer with 4 18s ... i wanted to view this because i drive an aviator which is basically lincoln's version ... i wanted to reference how he made the wall as i plan on building a wall hopefully in mine ... i dont think he did a straight wall because there isnt enough height to stack 2 straight up ... if anyone has any information please let me know thanks
if u need help fitting 4 18s on a baffle, give me the maximum dimensions that i could use on the baffle, the external dimensions, that i can attach the side walls too!
If your vehicle contours up higher in the middle, let me know those dimensions, etc...
I need dimensions so i can draw a blueprint of it so i can find out how 4 18s would go in your ride.
I think I saw one on YouTube with 4 18in btls in a clamshell.
these are the dimensions i have to work with ... this would be if i was to build the box inside the car which i am most likely going to have to do ... i am also willing to use birch instead of mdf so we do not need more layers of wood
front baffle - 38 high x 47 wide
back - 35.25 high x 38 wide
i forgot what the middle piece was ... i will have to look again ... i have written down 20 x 47.5 which cant be right ... odds are it is 30
depths
from top - 21
from middle - 30
from bottom - 36
this will probably only add up to around 21-22 cu ft
i also have a 15 wide X 24 long X 12 high area if i took out the middle seat to the back of where the wall would go ... this could be where the port would come out i guess
this is like 1.5 cu ft or so i would imagine
thanks again shawn
