Posted May 11, 200520 yr i have 3 seats in the front bench of my truck. when i sit in the middle, the imaging is pretty good. the singer's voice is in the center, guitars/drums/etc in their proper places. however, when i sit in the driver's seat, the horizontal bias is horrible. sometimes i hear the left tweeter a lot since its pretty close to my head (a-pillar), other times i hear my right mid over everything else (maybe cuz its more on axis?). the tweeters arent mounted for perfect imaging rite now cuz i dont have time to glass the flush mount cups to the a-pillars. theyre mounted above ear level and kinding pointing to the stomach of the middle seat so maybe thats the cause? lemme know whatcha think. i will eventually redo the a-pillers. thanks guys <3
May 11, 200520 yr I already told you what to do If you guys wondered:use the time anlignment and mess around with the balance
May 11, 200520 yr Author but theres no separate time alignment for the tweet and mid! i dont understand.is the TA measured from the mid or tweet on the HU?
May 12, 200520 yr i have 3 seats in the front bench of my truck. when i sit in the middle, the imaging is pretty good. the singer's voice is in the center, guitars/drums/etc in their proper places. however, when i sit in the driver's seat, the horizontal bias is horrible. sometimes i hear the left tweeter a lot since its pretty close to my head (a-pillar), other times i hear my right mid over everything else (maybe cuz its more on axis?). the tweeters arent mounted for perfect imaging rite now cuz i dont have time to glass the flush mount cups to the a-pillars. theyre mounted above ear level and kinding pointing to the stomach of the middle seat so maybe thats the cause? lemme know whatcha think. i will eventually redo the a-pillers. thanks guys <3<{POST_SNAPBACK}>Until you set up the imaging correctly the only thing I can think to recomend is the fade and balance. If your left side (tweet or midbass) is soundlig louder move the balance over to the right a few notches Do the same for the right side when it occures. I know it is a pain to have to constantly change, but if you do not have the time alignment and the imaging isnt correct its really the only thing that I can think of.
May 13, 200520 yr Might want to try changing phasing as well. This has been a huge help to me in the past. Crossover points and slopes as well.
May 13, 200520 yr Author thanx yall. i started my proper A-piller mounting today, gonna glass in the flush mount pods tweets pointing at opposite headrest. i'll let ya know how it goes. will work with phasing/TA if that doesnt help.
May 14, 200520 yr Author i screwed up on the first batch and wasted a lot of the cat's fur. too much hardener on a hot day.now i see why everyone says it gets really hot inside a plastic cup, crazy stuff.
May 16, 200520 yr those look like they are going to be mounted pretty high up, you sure you want all that tweeterness blasting in your ears???
May 16, 200520 yr Author too late now.i have no one to help me with stuff so i'm eyeballing stuff most of the time. sux.
