What do yall think about this?? will be going in my single cab 95 dodge ram
here are the particulars....
bottom 77 x 49
bottom 77 x 49
top 77 x 49
top 77 x 49
baffle 74 x 46
baffle 74 x 46
front 46 x 5
front 46 x 5
side 77 x 16
side 77 x 16
side 77 x 16
side 77 x 16
Port internal sides (4) 3 x 9.5
port external top 44.5 x 3
port external bottom 44.5 x 6
port external sides (2) 3 x 9.5
we are looking at 10 sealed and 17.75 ported
get dowels for bracing...
46x10 for the cutout to cab
10-11 feet of wood dowels for bracing...
i mean the dowels are 12 inches apart
fiberglass resin first then cover in bedliner... also resin the corners and dowels on the inside
so it'd be easiest to build the port outside the car
then slide it in
then screw it in from the sides
3/4 MDF sheets
its 5T x 19W >>>> PLEXIGLASS WINDOW
now make sure the inner lip is .5 bigger so you can flush mount the plexi on the inside.
like in the pics.
looks sick! Who did the design?
