Posted August 12, 200917 yr I don't want to keep bugging Jacob if other people here can help. I am building a ported enclosure for 2 Sundown SA 12's . A few questions , would it be good to tune them at 36hz? They will be on a Sundown 1500. Also, What i really need to know more then anything is the port dimensions. The max dimensions for my trunk is 22 Depth, 33 length, 16 Height. A sketch up would be really appreciated with the port calculated and what not! I will return the favor in some way*Shizzon are you around?* Edited August 12, 200917 yr by kwschs
August 12, 200917 yr I don't want to keep bugging Jacob if other people here can help. I am building a ported enclosure for 2 Sundown SA 12's . A few questions , would it be good to tune them at 36hz? They will be on a Sundown 1500. Also, What i really need to know more then anything is the port dimensions. The max dimensions for my trunk is 22 Depth, 33 length, 16 Height. A sketch up would be really appreciated with the port calculated and what not! I will return the favor in some way*Shizzon are you around?*i would help with a design but i am leaving work early today and wouldn't be able to get it done till tomorrow. i did some quick calcutions and you would have a box that is 4.80 cubes with a port that is 14.5 high x 5 wide x 16 long tuned to 36.67 hz, hope that helps some Edited August 12, 200917 yr by lil98cabrio
