Yes hello im new to this site but i find it very interesting and helpful luv it my question is if anyone can help me is this . I have 2 15 inch kicker l7 @4 ohms each sub has its own amp us amps md1d 750 watts @ 2 ohms im trying to find out if i can make the subs play at a lower ohm such as 1 ohm without hurting them or is there any other way to get the most out of them i have the amps strap together. Thanks for all the help mrcrown89
So each sub has dual 4 ohm coils? If so you can't wire an individual speaker down to 1 ohm, only 2.
If you want more power you mismatched your amps to your subs. You'd have to get a different amplifier(s). But aren't those subs 750 watts RMS anyways? Adding more power won't do much for you.
yes hello everyone great site luv it my question is that i have two md1d one on each kicker l7 15 @4 ohms how do i set them to play at its best and get the most bass out of them can i bring the subs down in ohm i have them both strap right now. Thanks for all the help Mr crown89
No need to start a new topic with the same information.
