Posted August 15, 200917 yr Yes hello im new to this site but i find it very interesting and helpful luv it my question is if anyone can help me is this . I have 2 15 inch kicker l7 @4 ohms each sub has its own amp us amps md1d 750 watts @ 2 ohms im trying to find out if i can make the subs play at a lower ohm such as 1 ohm without hurting them or is there any other way to get the most out of them i have the amps strap together. Thanks for all the help mrcrown89
August 15, 200917 yr So each sub has dual 4 ohm coils? If so you can't wire an individual speaker down to 1 ohm, only 2.If you want more power you mismatched your amps to your subs. You'd have to get a different amplifier(s). But aren't those subs 750 watts RMS anyways? Adding more power won't do much for you.
August 16, 200917 yr Author yes hello everyone great site luv it my question is that i have two md1d one on each kicker l7 15 @4 ohms how do i set them to play at its best and get the most bass out of them can i bring the subs down in ohm i have them both strap right now. Thanks for all the help Mr crown89
August 16, 200917 yr Author Yes hello im new to this site but i find it very interesting and helpful luv it my question is if anyone can help me is this . I have 2 15 inch kicker l7 @4 ohms each sub has its own amp us amps md1d 750 watts @ 2 ohms im trying to find out if i can make the subs play at a lower ohm such as 1 ohm without hurting them or is there any other way to get the most out of them i have the amps strap together. Thanks for all the help mrcrown89
