May 16, 200520 yr "75in^2 up to 120in^2 of port"he ment to say that anywere from 75in^2-120in^2 you will be fine.
May 16, 200520 yr still lost on this 75in^2 of port thing.area of port...height times width..u said u already have the port measurements, what are they?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 17, 200520 yr I'm using one, at the side.It is 25hx3.5wd x 6.04depthone port for both, or that size port each?if that's for one, u're good...if it's for both..i'd double it, the area anyway..and recalculate the length..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 17, 200520 yr I'm using one, at the side.It is 25hx3.5wd x 6.04depth<{POST_SNAPBACK}>if your only having one port make it bigger. something like 25hx7wxlenght. 175in^2 port for 2 18's....pretty sweet
May 17, 200520 yr Author yea 1 port for both,I cant make it any bigger.I only have 43.5in of width, subtract 36+ - 2in, and i'm only left with 5.5in to work with total, so that incudes the end of the box and split in the middle,
