I have neon tubes under the dash on my 05 Camry LE. The switch for the tubes is mounted on the trim under my steering column. I want to move it and my wired remote bass boost to the spot where the ashtray is. I can not figure out how to get to that part of the dash. It doesn't pop off when I pull and I fear I will destroy it. I don't see any place to unscrew it at. Any ideas?
Also, how about removing the guts of the cigarette lighter and putting the button part over the bass knob? You would twist the"lighter" to turn up the bass. I've see some turn their lighters into their push-button start, so i know my idea can't be that hard
Edited by Chainsaw
Its called trial and error bro. Try it, be careful and don't be afraid. Worst case you gotta go see a junk yard.
J
