Posted August 25, 200917 yr i have a popping sound though my sub when i turn off my radio or when i change a track, turn it on mute it will do it when i step on the gas , i first had 2 w6( old school 12s) and a directed 600d amp it never did it when i had that set up, but when i put this one in it started doing it after i played it cupble of times, so what could be the reason. Edited August 25, 200917 yr by mtx9500
August 27, 200917 yr i have a popping sound though my sub when i turn off my radio or when i change a track, turn it on mute it will do it when i step on the gas , i first had 2 w6( old school 12s) and a directed 600d amp it never did it when i had that set up, but when i put this one in it started doing it after i played it cupble of times, so what could be the reason.did u put the ground on the seat or somewhere where the car gets the hit points! where did u put it?
August 28, 200917 yr Author i have a popping sound though my sub when i turn off my radio or when i change a track, turn it on mute it will do it when i step on the gas , i first had 2 w6( old school 12s) and a directed 600d amp it never did it when i had that set up, but when i put this one in it started doing it after i played it cupble of times, so what could be the reason.did u put the ground on the seat or somewhere where the car gets the hit points! where did u put it?its under the(astro van) back seat but its all metal under there ( i sanded it down to the metal it has great connetction), i had my other amp grounded there and never did that(whats a hit point)
