Posted August 26, 200917 yr k im preparing to do a sound competition i had a custom box built for4 kicker l5's, but the company i ordered my subs from accidently sent me 2 l7's and 2 l5's will that mess up my system by running 2 of each i will b running 2 1000 watt amps both at 1 ohmso 2 subs to each
August 26, 200917 yr Never mix subs. Especially if you're competing. You'll end up with some weird harmonics going.
August 26, 200917 yr Author Never mix subs. Especially if you're competing. You'll end up with some weird harmonics going.well they wont be wired together it will b 2 l7's on one amp and 2 l5's on the other amp that wont b fine
August 26, 200917 yr It's not a matter of wiring, it's a matter of how the sound will interact. They're going to move air differently. Slightly different resonance, different power, a bunch of things. Instead of the sound waves being the exact same and blending together, they'll be slightly different and it'll screw things up.If I were you I'd get on the horn with that company, see WTF happened.
August 26, 200917 yr Return the two L5's for more L7's, the L7's are always louder even off less power.
