Posted August 29, 200916 yr Any ideas about this unit, i have someone wanting to sell it for 100 what's ya'lls thought?Also how does the rear input usb work?Here's the specs http://www.crutchfield.com/p_020DXZ775/Clarion-DXZ775USB.html?c=3&tp=5684&tab=features_and_specsChassis Size Code IEJ CEA-2006 Compliant Yes RMS Power Output 20 watts Peak Output 53 watts RMS Power Bandwidth 20-20kHz Preamp Outputs 6-channel Sub Preamp Outputs Yes Preamp Voltage 5.8 volts Display Color Variable Key Button Color Variable EQ Bands 3 Sound Shaping Type DZ-Enhancer EQ Wireless Remote Yes Steering Wheel Control Compatible --- Security Detachable face Flip-Down Face Motorized Parts Warranty 2 Years Labor Warranty 2 Years Expandability iPod Connection/Control Optional audio AUX Input Rear USB Input Rear Memory Card Slot No A/V Inputs No Bluetooth Compatible Optional Satellite Radio Ready Both HD Radio No Navigation No Changer Control Yes Tuner Tuner Type Not given FM Sensitivity 9 dBf FM Presets 18 AM Presets 6 European Tuning No Seek/Scan Seek Radio Data System No Playback CD Frequency Response 5-20kHz CD Signal-to-Noise 84 dB CD-R Playback Yes CD-RW Playback Yes MP3 Playback Yes WMA Playback Yes AAC Playback --- DVD Playback No Edited August 29, 200916 yr by saturnsound
August 29, 200916 yr Any ideas about this unit, i have someone wanting to sell it for 100 what's ya'lls thought?Also how does the rear input usb work?Here's the specs http://www.crutchfield.com/p_020DXZ775/Clarion-DXZ775USB.html?c=3&tp=5684&tab=features_and_specsChassis Size Code IEJ CEA-2006 Compliant Yes RMS Power Output 20 watts Peak Output 53 watts RMS Power Bandwidth 20-20kHz Preamp Outputs 6-channel Sub Preamp Outputs Yes Preamp Voltage 5.8 volts Display Color Variable Key Button Color Variable EQ Bands 3 Sound Shaping Type DZ-Enhancer EQ Wireless Remote Yes Steering Wheel Control Compatible --- Security Detachable face Flip-Down Face Motorized Parts Warranty 2 Years Labor Warranty 2 Years Expandability iPod Connection/Control Optional audio AUX Input Rear USB Input Rear Memory Card Slot No A/V Inputs No Bluetooth Compatible Optional Satellite Radio Ready Both HD Radio No Navigation No Changer Control Yes Tuner Tuner Type Not given FM Sensitivity 9 dBf FM Presets 18 AM Presets 6 European Tuning No Seek/Scan Seek Radio Data System No Playback CD Frequency Response 5-20kHz CD Signal-to-Noise 84 dB CD-R Playback Yes CD-RW Playback Yes MP3 Playback Yes WMA Playback Yes AAC Playback --- DVD Playback Noi have the newer version, which seems to be identical but im not sure if it has all the xover settings. id say, for 100 bucks, its a great deal. here are some pro's and con's...first the pro's - TA in the head unit is a great feature!! seems pretty rare to have it in such a low cost model..- easy to use (navigating the menu's are easy, the slider is will grow on you!!)- ipod control is great (note on the usb, u can plug your ipods usb right in and it will controll the ipod. this will also work with any other storage device, like a thumb drive or even a portable HD)- ability to turn off internal amp for better sound quality - customizable color display- design isn't very flashy (deters theft)now con's- display sucks when you have a glare- this unit, after check into it, do not seem to have the xovers like the new model. - design is not that appealing to some ppl id say, if you running passives and do not plan to run active OR if u already have an separate active processor (via amps, etc), this will be a great unit. for about 150 you can get the new model bnib.... for 100 i dont think you can beat this HU.
