Posted September 5, 200917 yr ok here's what i'll be running 2 HDC3 12's (copper series) on 2 aq2200d amps and ill have one deka intimidator 9a31 on each amp.so will this amp kit work? also will i need two of them since im hookin up 2 amps to two different batteries? http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0and then these wires to hook the sub up to the amp? http://www.knukonceptz.com/productDetail.cfm?prodID=KAR08SSthanks!
September 5, 200917 yr I think you might need a little more wire then that depending of the length of your car. I personally would just order the wire by length instead of buying a kit Edited September 5, 200917 yr by john denver
