Right now I'm looking for an amp to run a single 12" under rear seat of truck. Sub is a rockford fosgate p3, Thought I would poke around on here before asking questions ...
need to know if it's dual 2 or Dual 4 ohm.
It's rated to handle 1000w musical peak so you will want a 750w-1000w amp.. but still need to know ohm configuration on your sub.
O.K. These are the things I didn't know should be important. I dont have it here with me so I will find out and give the rest of the details.. Thank's
Hey guy's, It's a dual 4ohm. Just went and got it, It was free cant complain
The box fits under rear seat in my 99 gmc ext cab. It is sealed And is .90 cf. Budget is couple hundred, Not apposed to used... Help Thanks Steve...
you will want a monoblock amp that does around 500-1000w at 2 ohms.
all of the following amps can be purchased at www.sonicelectronix.com
Pioneer GM-D8400M - 600w @2ohm
Phoenix Gold Ryval V8001 800w @2ohm
Infinity Reference 1600a 600w @2ohm
Kenwood KAC-9103D 900w @2ohm
Sony XM-GTR6001 900w @2ohm
Cerwin-Vega Vega V500.1 500w @2ohm
Alpine MRP-M500 500w @2ohm
MTX Audio JackHammer JH300 600w @2ohm
All of those amps can be had for under $200 shipped.
One more question. Was just looking at the mounting depth of my box 6 3/4". My sub is 6.75. Is it alright to have the sub touch the back of the box?
No good if its touching, generally subs like a bit of space behind them especially if they have a pole vent...... Can you add a ring spacer or 2 ("space" the sub out more) to allow some clearance?
I got lucky, It's the older model and is 6.38mounting depth. Should give me just under a half inch of clearance .
