Posted September 8, 200917 yr hey everybody, a buddy of mine is looking for a decent/good quality amp to use for his daily driver. Hes running 2 Kicker CVX 15s, looking for around 4000wrms. He found a Powerbass that can do 4000wrms @ 1 ohm...just looking for some general feedback on these amps performance wise...do they put out what they say they do? Are they reliable amps? etc etcThanks!
September 8, 200917 yr hey everybody, a buddy of mine is looking for a decent/good quality amp to use for his daily driver. Hes running 2 Kicker CVX 15s, looking for around 4000wrms. He found a Powerbass that can do 4000wrms @ 1 ohm...just looking for some general feedback on these amps performance wise...do they put out what they say they do? Are they reliable amps? etc etcThanks!edit: powerbass products seem to be "OK" id look into that specific amp first tho. just make sure your friend understands what its gona take to run 4k rms. if your asking on how an amp performs id assume u may not be ready for the install required to run such gear. just a warning, sorry if it sounds dickish, but id hate for his build to suffer do to lack of know-how in regards to this type of install... Edited September 8, 200917 yr by lithium
September 8, 200917 yr Author hey everybody, a buddy of mine is looking for a decent/good quality amp to use for his daily driver. Hes running 2 Kicker CVX 15s, looking for around 4000wrms. He found a Powerbass that can do 4000wrms @ 1 ohm...just looking for some general feedback on these amps performance wise...do they put out what they say they do? Are they reliable amps? etc etcThanks!your going to have to look into wether or not they make rated power via someone testing that amp... i also hope your friend has cash to back up 4k rms electrically.. usuallly if you see someone talking about that kind of power they dont cut corners on the amp (assuming the amp is overrated...)its going to be his winter project....he has 3 HC2400s in the trunk + a 220amp alternator....I've been digging up on this amp and cant seem to find many people talking about it
September 8, 200917 yr hey everybody, a buddy of mine is looking for a decent/good quality amp to use for his daily driver. Hes running 2 Kicker CVX 15s, looking for around 4000wrms. He found a Powerbass that can do 4000wrms @ 1 ohm...just looking for some general feedback on these amps performance wise...do they put out what they say they do? Are they reliable amps? etc etcThanks!your going to have to look into wether or not they make rated power via someone testing that amp... i also hope your friend has cash to back up 4k rms electrically.. usuallly if you see someone talking about that kind of power they dont cut corners on the amp (assuming the amp is overrated...)its going to be his winter project....he has 3 HC2400s in the trunk + a 220amp alternator....I've been digging up on this amp and cant seem to find many people talking about iti know nothing of these crazy huge power amps myself, someone else will have to help you haha. i'll be running an 18" ib in my car with maybe 150rms haha
