Posted September 19, 200917 yr I'm planning on installing two 15 inch Fi Qs in a sealed enclosure and I am looking for a good set of components for my front stage that will be able to "keep up" with the sub stage.Thanks in advance.
September 19, 200917 yr Author What is your budget that your working with?Id like to stay at $500 or below.
September 19, 200917 yr I'd go to a shop or store, and listen to some and get an idea. Then try and find them online, are you going to need an amp too? We ran some Pioneer Ts-A502c's in my cousin silverado and they sounded nice to me.http://www.onlinecar...ProductID=19138The only problem with this, is everything is different to everyone. What one person thinks sounds good, could sound horrible to someone else. That's why I said go out and try to listen to them in person.You can also try the RSD's, I've yet to hear them in person, but they have had a cult following.http://www.onlinecar...ProductID=17540 Edited September 19, 200917 yr by patented17
September 19, 200917 yr Author I'd go to a shop or store, and listen to some and get an idea. Then try and find them online, are you going to need an amp too? We ran some Pioneer Ts-A502c's in my cousin silverado and they sounded nice to me.http://www.onlinecar...ProductID=19138The only problem with this, is everything is different to everyone. What one person thinks sounds good, could sound horrible to someone else. That's why I said go out and try to listen to them in person.You can also try the RSD's, I've yet to hear them in person, but they have had a cult following.http://www.onlinecar...ProductID=17540Ive got a Sundown 100.4 to use. This is all going in a Tahoe and I have pretty good amount of room for up to 7 inch mid if I fab up some MDF baffles.
September 19, 200917 yr Author A description other than 'keep up' would be helpful.Well, I want a good higher end set of components that will be able to have a good balance with the Qs. I dont want to have a bass heavy system. I like to hear everything. i have Hybrid Audio in mind. Im willing to raise my budget if the Legatia series will get the job done. Possibly a Pair of L6s and L1pros.
