Posted September 24, 200916 yr Im getting 2 12 BL subs and the saz 1500d sundown.Now i may just be getting just one sub for now cause of some money issues but wil end up getting another 12, can i hook up just one sub for now to the saz 1500d amp or no?I do not know shit about this stuff.thanks
September 24, 200916 yr Im getting 2 12 BL subs and the saz 1500d sundown.Now i may just be getting just one sub for now cause of some money issues but wil end up getting another 12, can i hook up just one sub for now to the saz 1500d amp or no?I do not know shit about this stuff.thanksSure you can, but you missed the main piece of information we need. What voice coil configurations did you order? D1/D2?The result that would best fit you is to have 2 subs with 1 ohm coils. When wired correctly you will end up with a 1 ohm load. But you would have to run at 2 ohms or at .5 ohms if you only had one hooked up. Edited September 24, 200916 yr by holley2346
September 24, 200916 yr you can but you'll need a D2 sub to get full use of the power. If your 100% your gonna get 2 12s eventually make sure you get D1 subs. That way you can show the amp a 1 ohm load with both subs.
September 24, 200916 yr Author Sure you can, but you missed the main piece of information we need. What voice coil configurations did you order? D1/D2?The result that would best fit you is to have 2 subs with 1 ohm coils. When wired correctly you will end up with a 1 ohm load. But you would have to run at 2 ohms or at .5 ohms if you only had one hooked up.I did not order yet, and im glad you told me that. and to the other poster, Im sure i will be getting the other sub.Just another question, when i have both subs set up and everything, am i going to need to do any upgrades to the car, i know the big 3 is a "must"but what about the alternator? or the battery?I want to be able to push them to their max potential.If i need to upgrade the alternator, do i need to upgrade the battery?or can i just get a yello top optima battery just for the amp/subs?thanks a bunch
September 24, 200916 yr Sure you can, but you missed the main piece of information we need. What voice coil configurations did you order? D1/D2?The result that would best fit you is to have 2 subs with 1 ohm coils. When wired correctly you will end up with a 1 ohm load. But you would have to run at 2 ohms or at .5 ohms if you only had one hooked up.I did not order yet, and im glad you told me that. and to the other poster, Im sure i will be getting the other sub.Just another question, when i have both subs set up and everything, am i going to need to do any upgrades to the car, i know the big 3 is a "must"but what about the alternator? or the battery?I want to be able to push them to their max potential.If i need to upgrade the alternator, do i need to upgrade the battery?or can i just get a yello top optima battery just for the amp/subs?thanks a bunchI added 2 optima yellow tops to feed my SA3000D. I still have not completed big 3 as I will do this when I get my HO alt. To answer your question, without the batteries voltage drops were dangerously low. After adding them I get fluctuations of .5 volts at full tilt. I would at least add 1 battery with at least 50 AH. But I would add as many as I could as long as I had the space and funds to do so. I don't know what kind of vehicle you have, but as long as you give the alt time to catch back up you should be fine until you do upgrade to a HO alt. Edited September 24, 200916 yr by holley2346
September 24, 200916 yr Author I added 2 optima yellow tops to feed my SA3000D. I still have not completed big 3 as I will do this when I get my HO alt. To answer your question, without the batteries voltage drops were dangerously low. After adding them I get fluctuations of .5 volts at full tilt. I would at least add 1 battery with at least 50 AH. But I would add as many as I could as long as I had the space and funds to do so. I don't know what kind of vehicle you have, but as long as you give the alt time to catch back up you should be fine until you do upgrade to a HO alt.Well i have a vw jetta so im sure your SUV has a higher alt. so i would have to buy the batteries? do i connect them directly to like the subs or amp? maybe i should just have the local dealer install everything for me =]
