October 22, 200916 yr Author well, the results shouldnt be all that good because i've got a lot of tweaks i can do to get it louder. I just want to establish a score first.No biggie, see ya in 4 months.
October 22, 200916 yr i'm either gonna be in Modified 4 or Modex 2, whichever the judges feel..It doesn't really matter because if the judges feel i need to be in Modex... i'm just gonna tear out my wall and create a shell in side my car behind the B pillar with a steel tubed frame around the whole box design to prevent flex if that's hwo they wanna do it, Or.. if they put me in Modified 4, then i'll see how loud i can get my wall.. I'm onyl runnin 7kw right now and if i stay in M4, i'll drop in 6 mroe batts and up myself to 24,000w.But until those times, this is my first sanction event, i've competed in non sanctions but just never sanction. I really don't care what i do the first couple times but after that, i'll start gettin down to business. all i need is motivation and goin to shwos wil do itI know just from looking at the state records and competing modex2 will be easier to get points in. Also in ky mod 4 was louder than modex 2. There's also allot more things that are permitted in modex 2 as well so there's more room for upgrading. I highly doubt you will be able to run 24000 watts through 329 amps of fusing even with spreding it over 4 fuses. I know this because my buddy is in mod 4, he has 8 15's and 6 sundown 1500's. He can barely get a burp off with just this amount of power.
October 22, 200916 yr I will be there competing in S2You changed classe again I thought you were gonna be in s1?
October 23, 200916 yr Author i'm either gonna be in Modified 4 or Modex 2, whichever the judges feel..It doesn't really matter because if the judges feel i need to be in Modex... i'm just gonna tear out my wall and create a shell in side my car behind the B pillar with a steel tubed frame around the whole box design to prevent flex if that's hwo they wanna do it, Or.. if they put me in Modified 4, then i'll see how loud i can get my wall.. I'm onyl runnin 7kw right now and if i stay in M4, i'll drop in 6 mroe batts and up myself to 24,000w.But until those times, this is my first sanction event, i've competed in non sanctions but just never sanction. I really don't care what i do the first couple times but after that, i'll start gettin down to business. all i need is motivation and goin to shwos wil do itI know just from looking at the state records and competing modex2 will be easier to get points in. Also in ky mod 4 was louder than modex 2. There's also allot more things that are permitted in modex 2 as well so there's more room for upgrading. I highly doubt you will be able to run 24000 watts through 329 amps of fusing even with spreding it over 4 fuses. I know this because my buddy is in mod 4, he has 8 15's and 6 sundown 1500's. He can barely get a burp off with just this amount of power.I currently run 4 80A mANLs.Assuming current draw would be ~845A, that's my belief in hopes it would hold...If it didnt, i can always adjust my master gain so it can only pull a certain amount of current so i don't accidentally pop a fuse when i go knob crazy.I only have 7kw now so i could actually run my comp fuses for daily if i wanted to...
October 23, 200916 yr I'm going. Plan on competing in AS2 if the fusing hold. I'll meet up with yall just give me a spot to be atFusing should hold on a 3000d . What ohm load do you have the amp running at and what type of fuseblock are you running? it's at 1 ohm on 2 12s (HDC3s)you can get a full burp off about 50 a of fuse with that amp.. .you shouldn't have a problem especially with impedence rise...
October 25, 200916 yr Author ok, just got back from the show and everybody that rolled with me... WE ALL GOT 1st PLACE!! Woohoo!ShiZZZoN - MX2-151.3Phi - AS1-140.9Ben Hemp - S3=148.3Josh Shacklette - S2-145.3\DB3-123.6We all got 1st place.Then, one of our buddies-Joshua Newton (Team Carlisle\Sundown\XStatic) - M4-155.6! (1st place)Paul Strouth was there! - M5 - 157.2db! (1st place)Paul Strouth also ran in DB5 scoring a 131.3db! (1st place)He uses 3 3500ds and a clam-shelled 6th order bandpass.I could have ran in M4 but decided not to and move myself to MX2 since i want Durock in my car next year... I would have beaten everybody in M4 except for Josh Newton... He runs 8 15s and ~250A worth of fusing burping between 30-35hz to achieve his 155.6db.
October 29, 200916 yr It was nice meeting everyone hope to see you at more shows this season hopefully my car will be ready by then.
