Posted September 27, 200916 yr Been working up some ideas and have decided to persue the latest idea. Attempting to be LOUD and PIMP looking but is quite the challenge to both. This one is more focused towards looking nice but should through up some descent numbers too. It isn't an SPL focused setup but surely at some point in time this year I will have something more towards SPL... just depends on how this one sounds. I am anxious to build something so here it begins.Here is my dirty VUEUnder the hoodCargo AreaThe Amps!Slot cutting with guide board held down by Josh... so much faster than clamping/moving lol. Thanks Josh!Testing flexibilityMore flexibility testingGravity at work
September 27, 200916 yr Author Closer lookCentering the center board and side boardsIt fits!A little closerInside lookAnother inside lookThis part of the enclosure is nearly finished... well not reallyStage IIAttached dowel rods tonight and added some 45º boards.
September 27, 200916 yr Author Closer LookInside Angle viewStage IIIMade the sides and put them on so you can *kinda* see what's coming.Another angle weee! Well below the window line although it is going to get a little higher but will still clear by plenty.And another angleCorner Shot... I like this view!Managed to get a little more done.More resin to sand down yay!
September 27, 200916 yr Author weeeStage IV3/24/2009Little more... still undecided on part of it but progressing.Another viewStage VDoesn't fit like you want it and spending more time trying to get it to work right.... have to karate chop it to move on lolCut some flush mount rings for test fitIt's gonna fit nicely!
September 27, 200916 yr Author Mounting rings attached to the flush rings and set in the enclosure.Fits like a glove... a tight glove.Angle shotPlopped Al's Powerbass 15's in it to see how it looks with the subs. Haven't decided what subs I am going to use yet.Top viewStage VI3/31/2009This next part is where I fill the gaps between the subwoofer rings and the front radius (done just a few hours ago)Made this from a ½" thick hard cardboard ring.Here they are setting in place.another view
September 27, 200916 yr Author again....Now I have attached them to the subwoofer ringsanother shotAnd now some resin so they can harden in this positionAnother shotagainand the last one for the night!Manged to get some filler added... lots of sanding/filling left to do.
September 27, 200916 yr Author Stage whatever...This is in place temporarily for resining/stiffening in its' form then it will be put back in later after I finish this section.Update 4/28/2009Added a layer of glass to the inner radius pieces. Will be adding a couple more layers to it tomorrow and doing some sanding in prep for the next stage.5/4/2009Got a little more done... weather has treated me a little better but not a whole lot.. hoping for a good weekend. Here is some pictures of the underside getting some attention. None of these pieces are permanently in place but they will be soon.
September 27, 200916 yr Author Stage 234,098,432May 22nd CompetitionOut with the oldIn with the new KDR900 JVCNew Toyz!!!Been waiting for these BadBoys!! Love em! Thanks Jacob!(2) 15" 2ohm DVC Sundown Nightshades!
September 27, 200916 yr Author Time to Break them in!Rubber gaskets are just sitting on top of the edge, just laid them there for the hell of it. Didn't want to put them on since they will be coming back out soon and they fit really tight in the recessed area.. not an easy task but love the fit.Pic from Finals! Been slacking on the build pics but here ya go! Still not finishedLights Vid Excursion Vid (not maxed) Burp Vid! Vid "footlongsam" took from MidwestSPL finals. Edited September 27, 200916 yr by BASSBOXMAN
September 28, 200916 yr i just found my most favorite builder / fabricator ever.......dude I have seen alot of builds, this one gots me all fuzzy feeling..... i swear my first reaction was if i had the cash, i would hire you for a full vehicle build! i need twice the pics, where did your inspiration come from? I have not seen these type enclosures before, (well maybe a couple of pictures from a vegas show), is that where you are from? too cool , i am really impressed, I can't get a rectangular box to look this good.thanks for shareing, chop
