Posted October 3, 200916 yr h im looking to run 4 of these subs maybe 2 unsure yet but im looking to get 2 3000 watt dc amps, will the level 5 18 be good for 3000 watts or is it not enough
October 3, 200916 yr so thatd be 1500 a piece, I think they are 2000 rms. You could do it and upgrade power later, You would notice a nice difference in the 2000 extra watts.
October 3, 200916 yr Author so thatd be 1500 a piece, I think they are 2000 rms. You could do it and upgrade power later, You would notice a nice difference in the 2000 extra watts.k so what if i ran 2 of them with 3000 watts a piece 1 sub to 1 amp would that b fine and how much cubic feet of airspace would i need for the box and how much port area
October 3, 200916 yr If you set it all up correctly you could run them at 3000 a piece, I believe they burp at 4000. I'm not sure how many cuft they need, probably 5-8 or 6-9. You could probably find out on the site.http://www.dcsoundlab.com/specs.html
