Posted October 9, 200916 yr I have the MB PVF 213's in kick panels, and want to install these in my door. It says to run wires through the 213's first then out to the 164's. Each has it's own cross over so why would you do this? I'm running them off a RF T600-4 4 channel amp. I thought you would just run the 213's off front channel , then run rear channel to the 164's and you would be good. Then set my cross over's on my RF 3sixty.2 to HP on front , get it were I want it at, then set the BP on rear where I want it at and it would be good to go. What am I missing? What would be good settings for the cross over points to start with? Thanks
