Posted October 9, 200916 yr I was wondering how much of an audible difference more port area would make. For instance my 12 is in a 2 cu. ft box with 2X13 port area which is 26 sq. inches of port. Would a 3x13 port make it that much louder or is more port area just desirable for chasing tenths on the tl. More port means a bigger box but is it worth it? I know higher tuning will definitely make it louder but i don't compete so i would never tune above 35 hz. Or perhaps i need a bigger sub . I'm more of a basshead than i thought.
October 9, 200916 yr if i could with my current install, i like tuning just under 40hz and set the subsonic down in the low to mid 20s. Make sure you use a sub that has LONG throw so it can be set like that, otherwise, that sub will get damaged quick.to answer your question, no, you shouldnt hear a difference because the new port area is no where near a major change.You would, like u said, tell a difference by tuning higher before u would increasing port area just 13sqin larger.Now, if u increased port area from 26sqin to lets say 60-80sqin... well, that might be louder to the ear... but too hard to speculate.
October 10, 200916 yr Author Thanks for the reply. I don't think i would want that much port area for a 12 for my tuning habits because that's a big box. Is 24 mm xmax enough throw for your tuning suggestion? I have the Soundsplinter rlp-12.
October 10, 200916 yr i'm sure it is, that's practically 2" p2p linear excursion. You should be able to tune to around 35-37hz and still drop low. Of course the lower you tune, the lower and louder it will sound though.Preferrably though, lots of people like 35hz unless you are a low-end-fiend, then 30-32hz is suggested.
October 10, 200916 yr Author Cool. My box is already tuned to 32 hz and i was thinking of tuning just a little higher. Most music doesn't go that low but when it does, man is it fun.
October 10, 200916 yr 1.35 cu ft net volume sealed 1.5 cu ft net volume vented, Fb = 34 Hz 1.85 cu ft net volume vented, Fb = 28 HzQts: 0.207 Qts: 0.219 Mounting Depth: 17.5 cm Qes: 0.226 Qes: 0.242 Total Depth: 18.5 cm Qms: 2.470 Qms: 2.266 Outside Diameter: 31.8 cm Fs: 23.43 Hz Fs: 18.856 Hz Weight: 35 lbs Re: 3.7 Ohm Re: 6.26 Ohm Magnet Width: 18.8 cm Ls: 4.060 mH Ls: 7.382 mH Mounting Cutout: 28 cm Rp: 7.478 Rp: 14.68 Displacement: 0.15 cu ft Vas: 87.73 L Vas: 142.7 L Mms: 177.9 g Mms: 168.8 g Cms: 259.2 u Cms: 421.9 u Bl: 20.70 T*m Bl: 22.74 T*m SPL: 88.81 dB SPL: 87.79 dB Sd: 0.0471 m^2 Sd: 0.0471 m^2 Xmax: 24.2 mm Xmax: 24.2 mm Tune to 30hz .
October 10, 200916 yr Author 1.35 cu ft net volume sealed 1.5 cu ft net volume vented, Fb = 34 Hz 1.85 cu ft net volume vented, Fb = 28 HzQts: 0.207 Qts: 0.219 Mounting Depth: 17.5 cm Qes: 0.226 Qes: 0.242 Total Depth: 18.5 cm Qms: 2.470 Qms: 2.266 Outside Diameter: 31.8 cm Fs: 23.43 Hz Fs: 18.856 Hz Weight: 35 lbs Re: 3.7 Ohm Re: 6.26 Ohm Magnet Width: 18.8 cm Ls: 4.060 mH Ls: 7.382 mH Mounting Cutout: 28 cm Rp: 7.478 Rp: 14.68 Displacement: 0.15 cu ft Vas: 87.73 L Vas: 142.7 L Mms: 177.9 g Mms: 168.8 g Cms: 259.2 u Cms: 421.9 u Bl: 20.70 T*m Bl: 22.74 T*m SPL: 88.81 dB SPL: 87.79 dB Sd: 0.0471 m^2 Sd: 0.0471 m^2 Xmax: 24.2 mm Xmax: 24.2 mm Tune to 30hz .Is that because the fb is so low?
