And 2 More Vids. With Our T3KW Design, Most Likely This Is How Im GOnna Be Running Most Of The Time
Then At Meets And Shows Ill Have The Screen With The HU Playing Some Music Videos.
Edited by Kent
  • Replies 60
  • Views 5.5k
Wait, I know that monitor is 22" but I dont remember cutting the hole for the plexiglass that big.... Did you cut the whole out bigger?? If so you are going to have to order another 3/4" thick plexiglass.
I like the fading effect you put on the team design logo. It turned out to be better than I imagined. Keep up the good work!
The Plexiglass Ran About $65 For That Size because its about 1 inch thick.
To Prep the box was about another $40
Abd i think the wood was about another $60
I am hoping you are talking about the entire box in general costed that much lol.
i am thinking about doing an amp rack and having plexi glass along the top....where can plexi glass be bought?
Home depot sells it. Not real thick I dont think though. I bought 1/4" from my local home depot. Just be careful because most of the pieces are scratched.
If you wanted to use it for an amp rack you might want to stiffen it up by putting a thin metal bracing along the bottom.
I was going to use plexi glass for the front/top and use mdf for the back/bottom because my amps were going to lean back against the back baffle
That should work. If you need to know any more information you should make a new topic because you are kinda threadjacking kent.
