October 23, 200916 yr Author I am running xcons and I plan on winning competitions Its not that, Im just looking for the absolute loudest with the best quality possible, if that makes sense. Im pretty sure that the decibel difference from the xcons to the mayhems is noticeable. By NO means am I slandering or insulting, just for my wants/needs I want/need as many watts flowing through my subs as possible... Im weird like that. I think Im gonna go with Mayhems, the 4500D and 1 XS3100, would that work for what my goals are?Ya. You should be fine with that. The mayhems will sound better than the btls. What are you running for a front stage?I havent made up my mind what I should do for front stages yet, but I want the best quality possible, any ideas?
October 23, 200916 yr Author Why havent you considered going with the xcons off a 3500d? The xcons sound great and get loud. It will be much louder than your friends type xs and will sound better too. You will have him beat in output and sq.For bracing you might want to run dowels and corner bracing. Also you might want to do a double baffle. Too much bracing is better than too little.Because those arent as powerful, I want to win some dB comps too, so if I get the Mayhems I should be able to.. And alright thanks, Ill definitely do that.. doesnt sound like a bad idea.The speaker does not produce any power. But your goals point you towards the BTL's or Mayhems.Ha thanks, I know where Im going just half-baked plan but yea, which one in your opinion? BTL or Mayhem?Really, flip a coin IMO. Both are well built drivers and both have serious potential to get very very loud. The BTL can be customized to your needs if that helps.True that, customization is nice.. Alright thanks
October 23, 200916 yr Well in order for you to keep up with those subs you are going to need a very powerful frontstage. Quality is something you are going to lack unless you plan on going active setup with image dynamics horns and a set of their xs69 midbasses. That will get very pricey though. Like $600 for the horns and mids lol. Not counting the active crossover and amp/s for the active setup.
October 26, 200916 yr Author what about ia wardens?I thought about it, but at $850+ per sub Id wanna push them to their potential, and F that, Im not gonna waste that much on amps and what not. If those are your flavor then more power to you lol but Mayhems FTW over here
