I'm trying to install them but the post are not marked which is positive and negative, how can you tell which is which?
Just guess. If you really want to set them up right to sound the best you'll want to play with phase anyways, i.e.- try switching + and - on each speaker one at a time to see if it sounds better.
you could also grab a 9 volt battery and if the speaker pushes forward the post that the + of the battery is on is the + post of the speaker if it pulls inward what ever post the + is on is the speaker negative
Used a 1.5v , I guessed right on 1 speaker , wrong on the other. Now both push out. Thanks for the help.
