Posted October 25, 200915 yr Need to replace my starting battery on a 1999 chevy s10 blazer.Whats a good replacement to keep up with around 1600 watts. It needs to be able to match up with a second battery in back if i decide to add one. If there is not a big deal i was just going to put in a die hard gold and be done,but want any imfo/help before spending money.
October 26, 200915 yr Starting Battery? Optima Yellow Top Or Red Top. Or The Appropriate Sized Powermaster Or Kinetik Battery.
October 26, 200915 yr Need to replace my starting battery on a 1999 chevy s10 blazer.Whats a good replacement to keep up with around 1600 watts. It needs to be able to match up with a second battery in back if i decide to add one. If there is not a big deal i was just going to put in a die hard gold and be done,but want any imfo/help before spending money.You can use the die hard and it wont matter if youre not adding. I use a die hard suv/truck series with 2000 and its fine. If you want to add though I would look into an AGM cell thats a little pricier. Not too much though.Just make sure your electrical is good. Edited October 26, 200915 yr by bigrank916
October 26, 200915 yr Need to replace my starting battery on a 1999 chevy s10 blazer.Whats a good replacement to keep up with around 1600 watts. It needs to be able to match up with a second battery in back if i decide to add one. If there is not a big deal i was just going to put in a die hard gold and be done,but want any imfo/help before spending money.Whats the back batt?I would get kentik hc1800 under the hud, should fit.
