Posted October 28, 200916 yr I am currently running 2ohm kicker cvr's on a zx750.1 ampi recently blew one of the subs. so i purchesed two kicker CVX's 12"s 2ohmsI was wondering how i should wire these two to the ampI kow the amp is under rated for these subs but i plan to get a better amp later on. I would asume the kicker 750.1 amp be good enough I dont need to push the VCX's to the max Becuse they are right behind the seats in a single cab 09 F150.
March 16, 201016 yr If the 2 subs are single 2ohm, wire the voice coils in parrallel and youll get 1ohm at the amp. You can also do the same for 2 dual 4ohm voicecoil subs.
