Have you tried freetranslation.com? The only thing is that sometimes it doesn't get words with double meanings correctly, like "back."
Every translator I've found online is different. Some are close to each other, so I really have no idea. I have some spanish speaking friends, but most of them just speak it and cannot actually write it out for me.
what do you need to write, I might be able to do it, or at least put it in terms that will at least get the point across. I know when my brother in law gets hammered he speaks it fluently, he does alright sober. I can ask him maybe, depending on what/how much you need to say.
Los cubetas de la trapiadora deben ser drenados solamente en el cuarto de orden y limpieza. NO vacien en ningun drenaje de piso, incluyendo los cuartos del bano. Limpie los fregaderos y las cubetas de la trapiadora después de que acaben limpiando.
I hope this works. (Yes I'm Bilingual/Chicano)
Edited by tech2332
Thank you so much!!!!
It's really hard to work with people you can not communicate with.
No problem,
I can definitely understand your position.
mi pipí es muy grande
No. Tus pipi es poketo.lol :peepwall:
"Tus"?? How many pipi's does he have?
"Poketo"? Were you tryin' to spell Pikachu? :tehe: Poquito means a lil bit
Here is correct version, " No, tu pipi esta chiquito"
Sorry I just had to school you. :peepwall:
Edited by tech2332
Mop buckets are to be drained in the house keeping room sink only. Do not empty into any floor drains, including the rest rooms. Clean the sink and mop buckets after you are finished.
ok let me try
my English is not perfect but is understandable
las cubetas deben ser vaciadas en el fregadero del cuarto de limpieza. (mop buckets are to be empty in the sink of the cleaning room.) no las vacien en niguna de las alcantarias de los suelos incluyiendo los baniios.( do not empty them in any of the sewer/drain or the restrooms) limpien los fregaderos y las cubetas despues de terminar(clean the sinks and mop buckets after you are finish)
edit
free translators will give you really odd translations
Edited by XxedgarxX
LOL! I knew it wasnt right but what the hell. You gave me a good laugh with that pikachu line!
Btw, I do want to learn spanish cause Im a :noob: so let me have it!
I tried learning spanish in both high school and college, with two classes in each, and just didn't work very well. I'm not good at it. Great at english, just can't learn anything else I guess.
