Posted October 29, 200915 yr Why is it that all of these specs are missing?Driver 12 Inch 15 Inch 18 Inch 21 InchFS N/A N/A N/A N/AQms N/A N/A N/A N/AQes N/A N/A N/A N/AQts N/A N/A N/A N/AMms N/A N/A N/A N/ACms N/A N/A N/A N/ASd N/A N/A N/A N/AVas N/A N/A N/A N/ASpl N/A N/A N/A N/ABL N/A N/A N/A N/AX-max N/A N/A N/A N/A
October 29, 200915 yr Why is it that all of these specs are missing?Driver 12 Inch 15 Inch 18 Inch 21 InchFS N/A N/A N/A N/AQms N/A N/A N/A N/AQes N/A N/A N/A N/AQts N/A N/A N/A N/AMms N/A N/A N/A N/ACms N/A N/A N/A N/ASd N/A N/A N/A N/AVas N/A N/A N/A N/ASpl N/A N/A N/A N/ABL N/A N/A N/A N/AX-max N/A N/A N/A N/AAre you going to buy it?
October 29, 200915 yr Because they are all built on a customer to customer basis, T/S parameters are not available. (i.e. so many different coil/spider combos)
October 29, 200915 yr Because they are all built on a customer to customer basis, T/S parameters are not available. (i.e. so many different coil/spider combos)Oooh....Nifty Would the .7ohm coils be safe for daily? (series, then parallel the woofers).
October 30, 200915 yr Because they are all built on a customer to customer basis, T/S parameters are not available. (i.e. so many different coil/spider combos)Oooh....Nifty Would the .7ohm coils be safe for daily? (series, then parallel the woofers).Depends on what amp you are running, but yes, perfectly safe
October 30, 200915 yr Hmm, Maybe A SQ Soft Part Version? Lol.Still Planning On The 21" Build In The Future, Either In That Geo You Mentioned Or A CRX From My Buddy Dylynn I Can Get For $650.
October 30, 200915 yr Because they are all built on a customer to customer basis, T/S parameters are not available. (i.e. so many different coil/spider combos)Oooh....Nifty Would the .7ohm coils be safe for daily? (series, then parallel the woofers).Depends on what amp you are running, but yes, perfectly safeSAZ-4500D (with full electrical to boot)
October 31, 200915 yr Because they are all built on a customer to customer basis, T/S parameters are not available. (i.e. so many different coil/spider combos)true true they did for me hooked me up real well
