Posted November 22, 200915 yr When using 2 batteries, what wiring setup is the best way to get the most out of both batteries? Thanks in advance.
November 22, 200915 yr When using 2 batteries, what wiring setup is the best way to get the most out of both batteries? Thanks in advance.a run of 1/0 for both positive and negative front battery to rear battery.
November 22, 200915 yr Author So if I run a 0 gauge from the alternator to the rear battery and run a 0 gauge from the negative terminal of the front battery to the rear battery I wouldnt get the same affect?
