Posted November 26, 200916 yr Alright, got my batteries, subs, sub amps, wires, terminal rings, HU, and crossover all figured out. Already have my highs/mids/amps. Working on an HT as well, looking to go surround 6.1 or 7.1 with 21" Maelstrom-X's as well, MTM with Kevin's Anarchy cheap tweet crossover. May get an HDTV... So, I want to be able to hook my laptop to my HU if I so desire, as well as to my HDTV to watch online on the HDTV.Will I need a special sound card? What kind of connector, as I believe the PXA-H701 will use up the optical cable/connector and the Ai-Net cable/connector.So far:6 Shuriken BT-80's 4 Hifonics BXi2610D'sAlpine W200Alpine PXA-H701HO alt TBDAlready have:4 Adire Audio Extremis 6.4'sKicker KX850.4 (needs repair for 1 channel's crossover)2 Adire Audio/CSS/Exodus FR125S'sKicker KX350.4 (bridge since FRs are 8 ohm)2 Vifa XT25TG30 1" Ring Radiator tweetsKicker KX200.1 (needs repair, blown)For home:looking for THX Ultra certified because I am told they must be able to drive a 4 ohm load to obtain this certification, Anarchy's are 8ohm, so MTM would parallel 2 per channel12 or 14 Exodus Audio Anarchy's, build the crossovers Kevin designs, use either the cheap tweets he designs them for or Dan Wiggin's XBL^2 tweets shhhhhhHDTV2 Exodus Audio Maelstrom-X 21's2 EP4000's (or EP2500's)I want the laptop to be able to hook up at home and in car.Thanks!Krypto
November 30, 200916 yr You will want to connect to the aux input of the W200, not directly to the H701. Not sure if the w200 has aux video to use your laptop to play movies though.
