Posted June 21, 200520 yr So basicly, box in trunk, 2 18's and 1 amp.for whatever db and iasca i guess, but for iasca i would have 2 amps
June 21, 200520 yr db drag would put You in Street max 1-2. this is a wall class where the current Top is 160.x.You are over the max for a street class (where You woulds want to be) because street C limits You to 1-18", 2-15"s, etc.
June 21, 200520 yr db drag would put You in Street max 1-2. this is a wall class where the current Top is 160.x.You are over the max for a street class (where You woulds want to be) because street C limits You to 1-18", 2-15"s, etc.<{POST_SNAPBACK}>i'd be in the street max 1-2 also wouldn't i? 2-15's...but my box extends past the cargo area
June 21, 200520 yr db drag would put You in Street max 1-2. this is a wall class where the current Top is 160.x.You are over the max for a street class (where You woulds want to be) because street C limits You to 1-18", 2-15"s, etc.<{POST_SNAPBACK}>i'd be in the street max 1-2 also wouldn't i? 2-15's...but my box extends past the cargo area <{POST_SNAPBACK}>If Your box is above the window line (lowest point of driver window frame) then yes.If Your box extends forward past the OEM cargo area, then yes.If You could keep it in the cargo area and below the window line, You'd be looking @ Street C. Current top is 158.x (iirc)
