January 5, 201016 yr Damn, that's the first truck box with an 18 in it I've seen. My buddy put a BTL 15" in his single cab behind the seats and that was ridiculous.
January 6, 201016 yr Here is a pic of mine for you. It will all be changing though. Keep up the good work.
January 6, 201016 yr Author NICE! I like a alot! I though about doing something like that with my middle seat as well. The brackets on the floor are perfect for mounting something in place. What are the dimensions on the box?
January 7, 201016 yr NICE! I like a alot! I though about doing something like that with my middle seat as well. The brackets on the floor are perfect for mounting something in place. What are the dimensions on the box?Beware of the middle seat. It is bolted to the two bucket seat and you have to take the whole thing out as one then disassemble. Then you have to re-install the bucket seats separately. The dimensions are all outer measurements.58" W x 25" H x 7.5" TD x 11.5" BDTotal of 6 cubes of space with the port being 4" x 10" tuned for 35 hz
January 7, 201016 yr Author NICE! I like a alot! I though about doing something like that with my middle seat as well. The brackets on the floor are perfect for mounting something in place. What are the dimensions on the box?Beware of the middle seat. It is bolted to the two bucket seat and you have to take the whole thing out as one then disassemble. Then you have to re-install the bucket seats separately. The dimensions are all outer measurements.58" W x 25" H x 7.5" TD x 11.5" BDTotal of 6 cubes of space with the port being 4" x 10" tuned for 35 hzMine just came off with a few bolts, but there is still a bracket sticking up a few inches. Got vids?
January 7, 201016 yr NICE! I like a alot! I though about doing something like that with my middle seat as well. The brackets on the floor are perfect for mounting something in place. What are the dimensions on the box?Beware of the middle seat. It is bolted to the two bucket seat and you have to take the whole thing out as one then disassemble. Then you have to re-install the bucket seats separately. The dimensions are all outer measurements.58" W x 25" H x 7.5" TD x 11.5" BDTotal of 6 cubes of space with the port being 4" x 10" tuned for 35 hzMine just came off with a few bolts, but there is still a bracket sticking up a few inches. Got vids?Sorry no Vids.... Been meaning to but I don't think mine is quite up to par yet. Thus the rebuild that will be coming.
January 7, 201016 yr You should have used fiberglass resin on that sonotube since its only made of hard cardboard. Couple layers will make it rock solid.
