Posted January 12, 201015 yr Am trying to calculate the exact cu.ft for a wedge enclosure. I tried a few different sites and got anywhere from 5.8 - 6.0 cu.ft. Since I needed the exact size I worked it out by hand myself. Here are my dimensions and what i got. Can anyone double check this for me please?Wedge DesignOutside DimensionsHeight = 22"Depth 1 = 10"Depth 2 = 20"Width = 39"Formulas used:Rectangle L X W X D Triangle0.5 (B X H X W)Since the design is basicly a rectangle and a triangle combination, thats how i calculated it.I got 4.12 cu.ft for the rectangle and 2.06 cu.ft for the triangle with a gross volume of 6.18 cu.ft.I also took into account that the 1.5" (0.75" + 0.75") thickness of wood that "attach" the triangle to the retangle along the length was removed and added volume to the enclosure.Does this sound right? Thanks Edited January 12, 201015 yr by wof131s
January 12, 201015 yr To make it easier, just use the average depth of 15". Then you essentially have a 39" x 22" x 15" box, aka 6.0 cubes.
